ENGINE
Engine Type4-Stroke DOHC Twin Cylinder H.O.
Displacement875cc
Fuel SystemElectronic Fuel Injection
CoolingLiquid
DRIVETRAIN
Transmission/Final DriveAutomatic PVT P/R/N/L/H; Shaft
Drive SystemOn-Demand True AWD/2WD
Engine Braking SystemNot Equipped
Active Descent ControlNot Equipped
SUSPENSION
Front SuspensionDual A-Arm Walker Evans 2" body (comp adjust/res.) 13.5" (34.3 cm) Travel
Rear SuspensionTrailing Arm Walker Evans 2.5" body (comp adjust/res.) 14" (35.6 cm) Travel
BRAKES
Front/Rear Brakes4-Wheel Hydraulic Disc with Dual-Bore Front and Rear Calipers
Parking BrakePark in Transmission
TIRES / WHEELS
Front Tires26 x 9-12; Maxxis Bighorn
Rear Tires26 x 12-12; Maxxis Bighorn
WheelsPainted Black Beadlock Wheels with Color-matched Rings
DIMENSIONS / CAPACITIES
Wheelbase107.4" ( 272.8 cm)
Dry Weight1,529 lbs. (693.5 kg)
Overall Vehicle Size (L x W x H)134.4" x 64" x 73.25 (341.4 x 162.6 x 186.0 cm)
Ground Clearance12.5" (31.75 cm)
Seat HeightN.A.
Fuel Capacity7.25 gal (27.4 L)
Bed Box Dimensions (L x W x H)23 x 38 x 10" (58.4 x 96.5 x 25.4 cm)
Front/Rear Rack or Box CapacityN.A./300 lb (136.1 kg)
Payload Capacity800 lb (362.9 kg)
Hitch Towing RatingN.A.
Unbraked Trailer Towing CapacityN.A.
Hitch/TypeNone
FEATURES
Cargo SystemLock & Ride, 2 Weather Sealed Storage Boxes
LightingWhite LED, High/Low
Electronic Power SteeringStandard
InstrumentationDigital Gauge, Speedometer, Odometer, Tachometer, Tripmeter, Hour Meter, Clock, Gear Indicator, Fuel Gauge, Hi-Temp/Low-Batt Lights, Coolant Temp, DC Outlets (2)
и по видео видно что подвеска мягче(комфортней)
